99 Passat 1.8t won"t start hot - Volkswagen Forum - VW Forums for Volkwagen enthusiasts
Reply
Thread Tools Search this Thread
Old 07-29-2008, 02:40 PM
Jym Jym is offline
Default 99 Passat 1.8t won"t start hot
This just started doing this when it's hot, most of the time it won't start you have to wait for it to cool down a little,new plugs and filters, runs great when it's running. No lights or codes on. Really appreciate any and all help, Thanks again Jym...
Old 07-28-2009, 11:37 AM
James,
Have you repaired your car yet? Mine is doing the same thing. 1999 Passat 1.8t. If engine reaches normal operating temp and then is parked for 10-30 minutes, upon return will not start until cooled off. Runs normal after starting and never stalls. No check engine codes. Maybe a crank sensor? Not sure. I'm sure others have had same problem but internet searches have turned up nothing. Any advise will be appreciated. Thanks.
Fugitive
Old 08-22-2009, 08:40 AM
Default Try this solution...
http://autorepair.about.com/library/faqs/bl799f.htm
I have the same prob, just Googled it, and the solution sounds like a good one. I'm personally worried that mine is inhabited by the spirit of Herbie
Reply
Thread Thread Starter Forum Replies Last Post
02 Jetta 1.8T getting hot only in hot weather centerline Volkswagen Jetta/Bora 0 01-18-2011 03:04 PM
No start when hot - 2002 beetle gringo7718 General Tech 0 10-11-2009 03:01 PM
won't start, won't jump? wearyourtruth General Tech 1 01-02-2009 01:29 PM
Jetta won't start-special warm/hot Eng. marcilui Volkswagen Jetta/Bora 5 11-25-2008 05:25 PM
Hot Start Problem buck General Tech 3 10-03-2005 09:25 PM
Tags
18, 18t, 99, beetle, cars, days, forum, hot, jetta, passat, review, start, volkswagen, vw, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
