Question about porblem involving fuel pump!
Old 06-27-2010, 02:25 PM
sk8nnc16's Avatar
Default Question about porblem involving fuel pump!
whats up guys,
well i have a 87 jetta 1.8 that i have been working on. it recently had a problem with the battery being drained because of a bad voltage regulator causing the alternator not to charge, i got that all taken care of i believe but now the car will run for a little while fine and then a loud winning noise comes from the rear of the car (probably fuel pump) and then it dies about 3 sec after the noise. might be coincidence but it seems like the car will run for longer when it is cooler outside. just went out to mess with the car today and its about 95 degrees out and the car is only running for about 20 sec before the winning noise and then shutting off. Anyone have any suggestions on what it may be, not trying to put a ton of money into the car considering its only worth a couple hundred dollars and i have heard the fuel pumps for these things are pretty high.
thanks in advance guys,
Old 06-28-2010, 02:34 AM
elrocco88's Avatar
It sounds like the fuel pump. have u checked the fuses??
germanautoparts.com has good deals on most parts.
Johnny Turner
03-12-2014 09:28 AM
huyuhy
06-20-2011 03:28 AM
Market11
05-03-2011 06:56 AM
blackedout01
01-05-2007 10:28 PM
phani_tavvala
01-02-2007 03:44 PM
Quick Reply: Question about porblem involving fuel pump!
