misfire on #2 and #3
Old 09-18-2014, 04:33 PM
whoistylerdurden's Avatar
Default misfire on #2 and #3
Help!!!! I have a 2002 Jetta with the 2.0L engine. The problem started as a mis-diagnosis on my part. I thought the cam posistioning sensor was bad, but ended up as the fuel pump. After installing the fuel pump and cam sensor, the car seem to be only running on 2 cylinders.
Here are the steps I have done with no improvement.
  • no bent valve
  • coil firing on all four
  • checked timing again
  • installed different set of injectors
  • new crank/cam sensors
I am really stumped and need as much help as I can
Old 09-18-2014, 08:17 PM
Welcome to the forum.
Old 09-18-2014, 08:55 PM
I did scan it and it threw a mass air flow, air temp, and cam position sensor.
Old 09-19-2014, 08:06 AM
If you read I said post the codes.
Old 09-28-2014, 11:08 AM
Hey I figured out the issue. The valve on # 3 and 4 cylinder was bent. That is why the cam sensor was showing a code. I do thank you for the help.
jonny2nipples
03-13-2010 12:24 PM
jetta jack
11-11-2007 11:40 AM
krazzz
06-08-2006 02:18 PM
krazzz
02-19-2006 11:07 PM
krazzz
02-17-2006 12:27 AM
Quick Reply: misfire on #2 and #3
