Key not in range
2014 GLI Key not in range
2014 Jetta GLI Autobahn, not a push button start. Decided to use the extra key after owning the car for 2 years. When I put the key in the ignition it said key out of range and the car would start for about a second and shut off. I replaced the fob battery with no help. All buttons on the fob are operational. I can start the car with the working key, then shut it off and insert the non working key and the car will start but still get the key not in range message, and can drive away like this I just can't shut it off and have it start without the working key. Any ideas on what I can do short of taking my car and keys to the dealer and fork over 120 dollars to get everything reprogrammed?
Yeah I called them today with the response 120 to look at and if we need to program the keys it will be an additional 120. So you can see why I don't want to do this and I am looking for an alternate solution.
Yeah my dealer quoted 245 us dollars plus tax for the key and programming. I did however find a key from a new wrecked Jetta the guy sold me for 25 dollars. I removed my key blade and replaced it to the new fob. I will call around this week to see if I can get it programmed cheaper away from the dealership. If not I will pay the 120 to get it done.
#7
Even if you get a cheap key from somewhere else you can't just swap the blade there is a reader coil in the remote key that that's used for the immobilizer that needs programming by a dealer.
#8
Yes I have taken my old key apart. The RFID chip is on the main motherboard. As I have stated in the previous it is from a wrecked Jetta and the model and FCC numbers match to mine. I will try to get it programed for the immobilizer at an automotive locksmith and if they can't do it I will have it programed at the dealer. The blade is replaced by removing the roll pin securing it sliding the bad out and inserting my blade then replacing the roll pin. No electronics in the blade.
#9
Tearing the fob and check the parts one by one isn't the right way to fix the problem. I have faced this issue many times, an urban automotive locksmith always helped me in resolving this fob issue.
