2002 VW Jetta Electrical Issue - Need Assistance
Old 04-16-2015, 10:25 AM
fallon_vii's Avatar
Originally Posted by Keithuk
All I can suggest without seeing the car is you need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing.
It's been scanned by me with an OBD2, but also been scanned at the shop and at NAPA - showed no codes thrown.
Am I missing something? Does a VAG-COM scan for more than other scanners or something?
  #12
Old 04-17-2015, 09:34 AM
VAG-COM\VCDS has more facilities than a EOBD scanner you can analyse each signal from components and plot a graph to compare. You can test each component to see if it operates correctly.
You can drive the vehicle with it connected, obviously you need someone to operate the computer not the driver.
Its the best tool you will ever buy for a VAG vehicle and I don't mean the cheap Chinese cloned cables of fleabay.
  #13
Old 05-27-2015, 12:51 AM
dwightb2015's Avatar
Default Use a hammer to hit the ground cable on the battery
Hello Fallon,
I have the same issue. I just posted a new thread on it before I saw your thread. When this stall happens all I have to do to get it running again is to take my hammer and tap the ground cable on the battery. It is at the point now that I don't even put the battery cover on because of how often I have to "fix it" by tapping on the ground side of the battery. I have had two different mechanics take a look at this and neither of them can figure it out.
  #14
Old 05-27-2015, 07:51 AM
Read your other post?
02-05-2011 12:53 AM
tevano
08-14-2010 01:54 PM
gillen192837465
03-03-2010 06:06 AM
vwjettafan
12-29-2009 09:09 PM
jettav03
04-09-2008 01:34 PM
Quick Reply: 2002 VW Jetta Electrical Issue - Need Assistance
