Starting Issues
Welcome to the forum.
We don't know what you've done to your motor or what you've tried but you could have a faulty 109 relay. This is the main power feed for the ecu, the car will crank over all day but it won't start.
Its worth carrying a spare 109 relay in the car as they can go faulty at anytime then you'll be stuck at the side of the road.
There are basically 3 reasons a petrol engine won't run.
1. Mechanically damage - broken timing belt or incorrectly timed timing belt.
2. Insufficient fuel being supplied to be burnt in the engine.
3. Insufficient spark to ignite the fuel.
Have you checked all 3?
You need to get your motor scanned for any error codes logged in the ecu and post them.
Well if it only runs with a push start I would check the battery and starter system if I were you, as that takes the most juice from the battery.
