golf 1994 diesel turbo electro qeastion fuelpump
Old 11-21-2015, 09:42 PM
tim1's Avatar
Default golf 1994 diesel turbo electro qeastion fuelpump
hey guys from the forum,
I have big problem and I hope to fix it soon so I can make it back to work on Monday.
somehow my fuel-pump wire burn up somewhere what is my guess because i have no power to it. (checked all the fuses,all good)
I hot wire a cable from fuel pump straight to the +battery and my car start and runs good.
so today I run 16 awg cable from fuel pump straight to the fusebox and hook it on number 18 (with tool, add a new circuits) the car start but will stall after couple min, and then when i start it again the time is shorter. it feels like something get hot and then turn off or something like that ?
what do I have to do to fix this problem ? thanks a lot Tim
Old 11-22-2015, 07:07 AM
Welcome to the forum Tim. Name:  VWwelcome.gif
Its hard to diagnose problems on the web when you can't see the motor.
Recheck fuses and connections.
Old 11-22-2015, 09:25 AM
tim1's Avatar
Thanks for your help, I can't do the test because I can't make it to the shop. Do you think 16 awg wire is to small ?
Old 11-22-2015, 03:32 PM
I don't recall the wire size to the fuel pump but 16 swg Standard Wire Gauge (I'm English so I don't use American Wire Gauge) should be ok to get it running.
eng97
02-07-2012 09:31 AM
08-14-2010 10:02 AM
Wesley
05-21-2008 10:15 AM
sparhawk
02-27-2007 04:46 PM
Quick Reply: golf 1994 diesel turbo electro qeastion fuelpump
