Oil leak
Old 01-14-2017, 07:35 PM
wheelsport's Avatar
Default Oil leak
While poking around under the hood of the Cabrio, I noticed some oil laying in the rings on top of the apparatus above the transmission that appears to be connect to the cooling system. I cleaned it up and went for a fifty mile drive. When I got home, I noticed a burning smell and looked under the hood. The oil is back on top of that same apparatus. I'm not sure but I assume it is an oil cooler.
Old 01-20-2017, 09:44 AM
wheelsport's Avatar
While poking around under the hood of the Cabrio, I noticed some oil laying in the rings on top of the apparatus above the transmission that appears to be connect to the cooling system. I cleaned it up and went for a fifty mile drive. When I got home, I noticed a burning smell and looked under the hood. The oil is back on top of that same apparatus. I'm not sure but I assume it is an oil cooler. Where is the oil coming from and how can I fix it?
Old 02-23-2017, 08:52 PM
wheelsport's Avatar
I found out that the leak was coming from a bad 'O' ring on top of the tranny oil cooler. The fix was quick by replacing the 'O' ring under the allen nut on top of the cooler.
Proctogone
02-20-2008 11:15 PM
cmac1
10-06-2007 04:35 PM
CHABRIO
10-19-2006 02:56 AM
bbliatkceh
07-13-2006 06:47 PM
monkeyfist
06-07-2006 03:44 PM
Quick Reply: Oil leak
