Blown auto transaxle
Old 04-13-2017, 04:31 PM
Dr. Chip's Avatar
Default Blown auto transaxle
My daughters 2002 Cab has been diagnosed with a bad auto transmission. Check engine light came on 2 days before its NYS inspection..It only shifts into 1st and 2nd. Estimates for parts and labor run from 3000+ for repair and 6K for a new trans. My mechanic is does not think its worth it..
Is there a reputable VW shop in lower Westchester County NY area who might be able to get a rebuilt or used one.
If not I am afraid we are going to have to donate
Thanks very much for the insights.
Old 04-14-2017, 06:06 AM
Old 04-17-2017, 07:38 AM
Dr. Chip's Avatar
Thanks Keith.
Yes the mechanic ran the codes. While I am not certain what they were, he and the transmission shop he uses confirmed the diagnosis of a bad transaxle. Lower estimate was replacement of valve body and solenoids.Highest was for new trans and install Also the error codes could not be cleared so I can't pass NY State inspection. Hopefully a warrantied (1 yr min) used trans can be found. If not I will have to donate the car.
Thanks for the suggestion though. Much appreciated.
540t1
06-18-2007 11:18 PM
Motor Carriage
11-16-2006 07:38 PM
bustedupride
08-01-2006 01:21 AM
madmax3493
05-18-2006 10:24 PM
ryan123321
01-07-2006 09:09 PM
Quick Reply: Blown auto transaxle
