misses under load
Old 07-23-2014, 09:10 PM
trickdog's Avatar
Default misses under load
'64 bug, 40hp. I've cleaned the carb, checked plugs and timing and fuel pump. Compression and valves OK. It continues to seem to back down to running on 3 cylinders as soon as any load is put on the engine. Any ideas? Please ask further questions to help me in diagnosis. I don't want to just start tearing into things.
Old 07-24-2014, 02:53 AM
What are the compression readings?
How have you checked the plugs only visually?
Check the distributor cap and rotor arm for any cracks.
Old 07-24-2014, 07:00 AM
trickdog's Avatar
Compression = 125 all around
checked plugs visually - all look like they're firing
will check cap&rotor for cracks.
Old 07-29-2014, 06:32 PM
trickdog's Avatar
Keith, Thank you. Plugs were it. I checked and cleaned everything else too. Runs like a top.
Dieter
06-29-2010 04:15 PM
cris2for
05-23-2010 09:35 PM
mot bosco
05-06-2009 11:29 AM
ZSteinle
02-14-2009 03:28 PM
martyfarty69
02-16-2007 01:23 AM
Quick Reply: misses under load
