backwards battery!!!
Old 02-04-2006, 07:14 PM
exojj's Avatar
Default backwards battery!!!
ok, got my 74 super beetle, it died on the way home. so i was doing some work trying to figure out what is going on. I went to hook my battery back up, and i hooked the red cable to the positive, and the black to the negative of course. Not until about a minute later I realized the cables are reversed color! the negative cable is the red one! But how I realized this is that over on the left side where the cables go into the body, there was a white wiring harness looking thing that started smoking and getting real hot! i quickly disconnected the battery. Before this happened, when i turned the key on, both the engine and the oil light would turn on. now, even when the key is off, just the engine light is on. when i turn the key over, only the oil light comes on.....does anyone know how damaging this could have been and what it might have damaged if so?
Old 02-04-2006, 07:37 PM
Jsd's Avatar
Jsd
Jsd is offline
Default RE: backwards battery!!!
Good chance you fried the wiring harness. Never seen it happen before so perhaps other members can offer you some help.
-Jeff
Old 02-04-2006, 08:21 PM
exojj's Avatar
ok! thanks much![8D]
03Jetta18T
07-30-2008 08:17 PM
sknyppy
02-09-2007 12:20 AM
covergirl
09-24-2006 05:09 PM
redoo
07-31-2006 11:39 PM
kirsty willett
12-20-2005 03:13 PM
Quick Reply: backwards battery!!!
