91 Vanagon - Stalling
Old 10-14-2008, 10:33 PM
DanielDred's Avatar
Default 91 Vanagon - Stalling
Hey
My 91 Vanagan starts, idles and runs fine for a couple of minutes, then stalls. It will start straight after it stalls, then it idles, then dies again, etc.
Has this happened to anyone else? I can't work out what's making it happen.
Thanks
Old 10-15-2008, 05:59 PM
Jrailer's Avatar
Default RE: 91 Vanagon - Stalling
are you loosing power to the coil?
hook a test light up to it and see if it goes out as the car dies
same with the fuel pump
Old 10-16-2008, 09:41 PM
cpvwman's Avatar
On the throttel body, there is an electrical switch. If that is not adjusted properly, you will have problems with you idle. My old 86 vanagon syncro did what you are describing until I got the switch adjusted.
Andre
04-24-2007 12:20 AM
vwmamma_22
04-20-2007 04:25 AM
thedude60126
04-10-2007 12:53 PM
jeepwillies
03-07-2007 06:53 PM
jeepwillies
07-11-2006 06:16 PM
Quick Reply: 91 Vanagon - Stalling
