2.0L check engine light/engine codes
Old 05-02-2008, 09:44 AM
lilngineer's Avatar
Default 2.0L check engine light/engine codes
I am new to the forum and hoping someone can help...
We recently bought a 1996 Cabrio w/2.0L engine (165K) and the check engine light is on.
I went to AutoZone to have the codes read and are as follows:
P0422: Catalyst efficiency low-bank 1 - The PCM has determined that the main catalyst efficiency for bank 1 is below threshold for the current engine operating conditions.
P0102: MAP/BARO or MAF sensor condition - The PCM has determined that the mass air flow input is lower than expected for the current engine operating conditions.
P0172: Fuel trim bank one condition - The PCM has determined that during testing, the fuel system for bank 1 was too rich.
Does anyone know what might be throwing these codes? Are they common?
I reset the computer, but the light came back on. Any help is greatly appreciated. Thanks!
Old 05-02-2008, 07:57 PM
Jrailer's Avatar
Default RE: 2.0L check engine light/engine codes
try the air flow meter first
it might be seting off the cat and fuel trim codes
Torchia32
10-24-2013 07:19 PM
jespada125
01-30-2013 12:24 AM
lilngineer
05-02-2008 09:42 AM
magea
10-18-2007 08:12 PM
magea
10-08-2007 10:55 PM
Quick Reply: 2.0L check engine light/engine codes
